I recently got an aftermarket brake light for my bike and when I finished installing it I noticed that when I pulled the brake lever in, it would not light up brighter, but was lit in general. After I took the wiring harness (one that houses the rear turn signals and brake light) and did a continuity test on all the pins to make sure they were good which they all were, I have also checked the fuses and they are also good. I am very confused on what to do next.
As well as that I noticed my headlight was out and the bulb and fuse were both in tact, this may help with additional information but when I turn on my bights the light on the cluster gauge does not light up either, but the front turn signals still work.
Any help is appreciated, ride safe.
Ron
Ron
