I adjusted the brake line on the handlebar, undid the nut a bit to swivel the line in a different direction. The manual says to use new washers, but not sure if that means when installing a new line only? Do you think I would be ok? If I should replace the washer, is it a part I can get a napa or dealer only?
If it's not leaking.....don't worry about it
+1 to what he said
The copper crush washer is nothing more than a gasket...as long as it isn't leaking then it's fine.
