New to motorcycles, I've had my 03 650 custom for almost a year. My brake pedal has recently begun to stick. How involved is opening the brake assembly and what can be causing it? Do I need to worry? I've been able to lift the pedal up manually when needed.
Thanks!
It's part of the floorboard mount right under the brake peddle, it's side by side with the brake light switch
(it's a small spring). One end hooks the the long rod going back to the brake drum and the other into the floorboard mount.
