Can the brake rotors be turned like car rotors or do they have to be replaced and where is a good place to purchase. Thank you. jz
You have to replace them. Mine had a few cracks and was scored pretty good.
They are easy to replace.
I ended up buying a new one off of eBay for 65 bucks.
Depending on which bike you have, they can be obscenely expensive.
If the rotor is a bit scored and you want to put new pads on it, if the rotor is still above the minimum thickness you can put new pads on, and they will quickly wear in to small grooves or ridges on the rotor, without compromising your braking power too much.
This is one of those things where you need to have some experience to know when a rotor is still ok, or when its shot. If your brake pads wore down to bare metal, the rotors may be shot.
