1 - 18 of 18 Posts
the tuning forks is just the Yamaha logo
the other two.. I would guess are for the odo?
The button on the left is for switching between the trip odometers. The one on the tight, clears the trip odometers.
When you hold them both down. You can change the time. A manual for your bike can/should explain how to use them.
Ride Smart! Ride Often!
Thank you :)
It lights up green when pressed..
I can only find the 2000 Road Star owners manual... says nothing about that
I got nothing! I guess green is good whatever it means.
boy this bugs the hell out of me now because I cant find anything on that tuning forks button
google shows nothing - owners manual says its not there...
it does not make sense that it lights up when you push it, because when you have gloves on you would not be able to see it light up when you push it, your finger would cover the button
Try pushing it at night and see if maybe it makes the instrument cluster light up brighter? I cant think of any other purpose. Does it stay on when you push it once? Emergency flashers maybe?
Edit: earlier Road Stars do not have the 3rd button
Discussion Starter #14
Man I must be loosing my mind.. I just went down to try it again, and nothing.. When I pressed down on it at the gas station could have sworn it lit up.
I am losing it...
actually that makes sense
where was one of those on my 650, it was just a sticky logo, I pealed it off and threw it away
or it might be covering a screw that holds the instrument cluster to the gas tank.
1 - 18 of 18 Posts
