Hello everybody, I need some help on a question i have about a fitting on my bikes carb.
this fitting is directly between the two carbs when your looking down at the carbs with the airbox removed.
It appears as if it's a tee the ties together both carbs. it looks like a barb type fitting that a hose or a plug would be on it but nothing is on it and i need to know if there should be something on a plug or? it is wide open right now.
any help would be greatly appreciated
Sounds like the vent. It's suppose to have a short piece of rubber hose with a filter on it :confused:
Thank you, it's been driving me nuts.
I guess I will be ordering that missing part then.
Thanks Again
