I noticed today while syncing the carbs on my bike.. it sounded better when i did it by ear.
2002 vstar 650 classic
Having some MPG issues and whatnot, started the bike warmed it up and drove it for a bit. I came back and while it was running (since i planned on syncing anyways), just to use a screwdriver and see if it made any noticeable difference. I turned the screw 1/2 turn left and it didnt sound better. I turned it back to where it was, then 1/2 turn the other way... ill be damned. Sounded great, rpms increased, flawless throttle response.
The only problem was than when i hooked up my homemade manometer, it was not synced at 1/2 turn, but more like .10 turn from where i last synced the carbs.
Anyone explain this?
What I do when I sync my carbs is to bring it in sync at idle then I rev up to around 2000 rpm and check it again at that setting. I usually have to fine tune the sync a bit more but after that it rides gooood :).
Might have to try that as well. I did notice that when revving the engine a bit between the manometer would fluctuate a an inch or so and if i held it, the rear cylinder would pull more fluid towards it.
One article I read about carb syncing said rpm will decrease when the carbs are properly synced.
However, I just did a quick carb sync. I only needed a tiny nudge on the screw to get them perfect. But it did seem to audibly increase rpms when I made the nudge. I also had a tach attached (of course it fluctuates), but it started reading higher.
I thing I have absolutely verified. I can let the bike idle for 6-7 minutes and get the needles perfect. Then if I ride 3 miles and do it again, it will be off some. Idling for several minutes is no substitute for riding a few minutes.
There may be multiple factors that would cause the idle speed to increase or decrease.
Im wondering if it has something to do with the a/f ratio in a particular cylinder. I have adjusted PMS screws to compensate for the slip on exhaust that i have, and if i start the bike on choke, the rear cylinder chugs out some smoke. Nothing major, just excessively rich... i dunno... pulling at strings here
I'm by no means an expert but I would think when everything is synced correctly the RPMs would naturally increase. Think about it...everything is getting even & smooth amounts of air & fuel. Just seems to me to be only natural to expect a small increase.
