2003 Vstar 1100, got the carbs cleaned, cleaned the tank, new petcock... when I cranked it, it ran but then stalled, bunch of fuel on the floor, it’s leaking from the little tube, I circled it, 5he picture is taken from the left side of the bike in between the cylinders. I can see where there is any tubes left to attach to this... I wonder if it some kind of overflow of some kind.
Anybody have any idea why this would happen or what this tube is?
Discussion Starter #2
I have an appointment at the local dealership Ron Ayers Motorsport on May 17th,,, I am going to let them make it right for my wife to ride...thanks for looking...I think I might have a stuck float...I thought y’all smart asses, oops i meant Smart guys would be of more help...lol
I'm not good at carb diagnostics but your theory about a stuck float makes sense to me. Anyone else have a better idea?
isnt there also an adjustment on the float height, if its too far off it overflows?
when you said you got the carbs cleaned, its not clear if you mean you 'got er done' or had someone else do it
if that is the overflow tube port the tube should be running down to the side of the crankcase - if there is nothing there you need it replaced
having your float stick and the carbs overflow is bad enough, without having the gas land on your pants and the hot cylinders
Carbs have been cleaned by myself, new float needle valve installed...I am sure I missed something....I will let the dealership check it out before I let Mrs Notgrownup drive it...
taking the carbs apart to clean them is both tedious and error prone
if you take a photo at every step, and make a drawing of where each part goes, and carefully put the parts where they wont get bumped or disturbed if the job gets interrupted for a few days, then its just wrenching and phillips screws
There have been a lot of people that jumped into it, had a part fall out and they did not know where to put it back (so they left it out) or got things put back in out of sequence
the exploded bike drawings at bikebandit are helpful - goto their home page, select OEM parts, then Yamaha, pick your bike model and year, then on the left side of the screen you can pick OEM parts, the section of the bike you are working on, and it will show the carbs (for example) completely exploded apart, with each little washer and screw and jet numbered and named and with a price if they sell them.
It also shows the price for an entire new carb (hope you are sitting down) which makes you feel pretty good about fixing yours instead of buying two new ones!
A few people have been able to figure out where they went wrong just looking at those drawings. The problem with just taking a carb apart and cleaning it, and putting it all back together is that usually you are doing this because its not running right, and a previous owner may have put a part in the wrong place, or backwards, or a part falls out of the float bowl, and then you dont know what goes where.
