Does this look like a stock needle? The reason I asked is I ordered another one from partszilla and the picture they have only shows one slot on the needle. I lost the e-clip and it looks like you can only buy the hole setup with the needle.
They are definitely dyno jet needles I ordered all stock size jets for the carb and I bought a pod kit that came with the main jets. I lost the c -clip trying to change its position on the needle for the instructions of the pod kit. So maybe that was a blessing because it might have been in the wrong spot on the needle?Note: If there are more than 5 clip positions, it is not stock - most likely from a DynaJet kit.
you can check the tuning section of the WKb for info on needles. if you have dyna jet needles you probably have dyna jets too.
So if the center notch is the same as the single notch? Would I move the clip down one from that notch for my pod kit or no?Just use the center notch, is the same position as the single notch. Put them side to side to confirm. Here's link to info, about halfway down page.
V-Star 1100 Wiki Knowledge Base - Carb Jetting
It is rarely necessary to purchase a "jet kit" to correctly set up the V Star 1100 carbs. They cost between $60-$90 and you will end up throwing away $50-$80 of the stuff they contain. Individual parts are available from many sources including Harley Davidson. Follow all of the instructions below,sites.google.com
Sorry for all the questions and thanks for the help fellas I appreciate it! I booked marked that wiki and have it on hand I’ll tackle all this as soon as the parts land🤙🏽What Nick said 👆
Just follow the link above I posted.
I here ya. I’ve only had nothing but fuel injected sports bikes still have 2! I was. given this V Star from my uncle. Went to put a pod kit on and lost the e-clip on the needle in the carb but realized they weren’t stock when that happened so now I wait for a stock kit to arrive I can give this carb a good cleaning and not have to touch it for a while once it’s put back together and I know exactly what’s in it and how it’s setup Incase a issue pops up down the road 🤙🏽I often read through the various carburetor threads like this one, mostly because I've always been amazed that carburetors work at all plus it is interesting to try to glean general knowledge from the many experts that obviously have many years/miles of experience.
Then I thank my lucky stars that I have fuel injectors......
Right up til one of those electromechanical devices throws craps in the middle of nowhere..... but then I'll have to hope I can get her in on one cylinder.![]()
This is exactly what I have now. The carb did have dyno jet needles and jets. The dyno jets main were cj110 in the front cylinder and cj108 in the back cylinder but I took those out because the pod kit came with the 150 main jets for both cylinders. And both pilots are 17.5. I am just waiting on the stock needles and e- clips to put it all back together.Not sure which jets you are using. Here’s a very good reference link.
