1 - 15 of 15 Posts
Notam to 2018/2020 Trans Continental, or Upgraded Eluder cowboys and cowgirls...
Regarding the performance of the C.B. radio...
Ever since my bike was new, received last year, I always felt the C.B. Rx meter (five bar light up) on the self Diagnostics page, was weak. I'd only get one strong green bar, with a flash or two of the second...flash, here, flash there...
My Squelch and white noise background was always, in my opinion, (and having used a C.B. for R.V. camping and marine all my life...) was way too intense. I felt that I did not have a good ground, and/or signal feed from the back end, into the antenna input of the radio.
So......I removed the lower right section of the fairing...that exposes the Power Head and the C.B. radio body that sits down below and just in front of it.
Now to the matter------> If you remove same lower right quadrant, you will see the Antenna cable feed connection, sitting vertical on the forward facing edge of the C.B. radio body. THAT is what you need to address. In coming across the ocean, (salt marine air) in the hold of a freighter, that friction connection can become highly oxidized or even film-corroded, (as mine turned out to be...!!!).
When I pulled apart the line-in, socket, I found the parts had a very light white film on the surface, that as soon as I cleaned both right off with 0000 steel wool,...buffed, and then added dielectric grease, to the male and female of the connection...and when having mated the connection once more, I was now getting a FULL GREEN 5 BARS on the C.B. Antenna Rx meter, on the Diagnostic Page of the Power Head software. I put the fairing back together...and headed out onto the 401 (in Ontario)....and starting asking for a Channel 19, 'Radio Check'. I was getting hits all over the place, where before, hardly any. I asked in the C.B. lingo...how many 'pounds' I was punching out...and most everybody came back, "at a hundred!". Talking to one trucker, on a very high gain, clear transmission, with the SQ set to only 3 out of 14....I was 'punching out' at over 2.5 miles!
So...no matter WHAT you 'think' is a good C.B. Antenna Rx performance, most likely, you are losing out around 80 percent of the receive and transmit range, because of a filmed over, male/female antenna cable connection, at the C.B. body (on the vertical). If having a great and strong TX/RX C.B. performance matters to you...I highly suggest you take the 1 hour to RE and RE the lower Faring quadrant, give some loving to the male/female Antenna cable connection, leading in from the back end...and then give the male and female sides, a good coating of Dia Grease. Your C.B. will thank you...as well as now you will be able to call out for road construction snafu's...as far out as 2 to three miles from your '20'..... :) Gotta get some of the C.B. lingo in there....
Having a C.B. radio was so very important for my wife and myself...(on our 2000 GoldWing...(it came standard) we NEVER, EVER, were caught coming into the back end of a 3 mile long traffic accident clutter-F...or one caused by three lanes, into one...that radio saved us from crawling, stop and go...
A C.B. being standard on the SVTC, was one of the major, (not minor!) reasons that I chose our new ride...let alone everything else that came standard, that would have cost us thousands more on a Harley, or some features not even available on said Harley, 2018 Honda ST-1800, or Indian.
If a powerful C.B. radio, that the SVTC possess, means anything for you....clean out the 'wax' from its ears on the rear left,....and enjoy the new performance of seeing 5 green bars light up, after you ask for a "Radio Check" .....and then on subsequent rides..."Looking for a South or North bounder...what's over your shoulder?....." Avoid the three mile cluster-F...four miles ahead of you...and ONLY because you had your C.B. radio on C19, running in the background....while Led Zepplin, is playing in the foreground...LOLOLOLOL, 'Joe Style'.....and Dee-Dee is listening to something else, in SVTC-Yamaha exclusive, Duo Zone, or talking to one of her girlfriend's over horses...and dates to ride, over BlueTooth...
Motorcycling Life....is good...:)
Cheers,
Joe
Great bit of diagnostic work there Joe.
Another item for my maintenance checks at 4000 mile oil change.
Thanks for the write up.
Gary
Gary
No problem...glad to help. Since I gave that connection some 'lovin'...anytime I test the Rx...on the page...wham, bam...5 green blocks light up as soon as somebody answers my hail. Before, straight out of the shipping crate...1 full, and the second, flashing weak. Also, my white-noise is about 70 percent lower, than what it was, as the radio was signal input, starving....
What I did discover though...is that the radio is not schlepp...you know...let's give them one, on the cheap. This Midland unit, puts out hot...and I am even thinking of swapping out the OEM antenna, for a 3db gain custom...that is allowed by the manufacturer...you can 3db gain the signal input section of the radio, but no more than that...:) I can now with the OEM get out easily 2.5-3 miles from my '20'. A 3db gain, would punch out towards 4.5-5. There's no way, that you would ever come into the back end of a cluster....if your radio reached out 4 miles! My experience anyways. Believe me, this Midland is a great stand alone unit...and is twice as powerful as my 2000 Honda Goldwing radio was. I just wish..(off topic, I know...) ...I just wish that Yamaha would have gone with Garmin for my navigation gripe, rather than Harman Kardon, who is now owned by Samsung... That is truly, my only gripe of the SVTC. This coming update is supposed to address the vapid short-comings of the HK navigation. We'll see...crossing my fingers. I've had no engine problems...not one...great 43 mpg...all the time...very reliable...has never not fired right up...and since going to Royal Purple Max Cycle 10W40...I only now hear the thrum of the exausts...not any mechanical coming from the jugs....and will be staying with that as well, for the life of the bike...
Joe
Chief (Tony)...I was reading on the 'other' site, on the thread, CB and CB antennas... that at least three other SVTC owners were not getting any signal input...and were asking for help. Nobody was pointing them in the right direction....
I'm not on that site...so i might ask that you get on there, and post a link to this thread. It will most likely be the read that will correct most all of their low to zero radio chatter, and signal receiving issues. I think now that probably EVERY (shipped from Japan, via marine....) will have an affected CB antenna male/female film on the mated parts, also, they need to...and I forgot to mention this...there are actually three locations in the wiring harness where feed from the CB antenna travels to the input head of the Midland CB Radio.
1. Take off your seat,
2. Remove the three screws on the black cover that seats just aft of the co-rider saddle position...(there is a CB connection that is the first, leading from the antenna, that connects from the actual CB antenna, to the wiring harness that leads up to the radio itself. Then, there is one that is amongst the few that would be sitting just UNDER the co-rider's butt., Finally, the third, is at the radio input connection itself. That one I covered in my post.
So, basically take your seat off...remove the back plastic shield, aft of the seat position, and from the CB antenna lead in itself, make sure that all connections are taken apart, connected, taken apart, a few times to seat them and friction remove any film...then...place a dollop of dielectric grease on all the three connections from the back end, up to the front...seat all connections male/female securely, and then turn on your bike to ACC, access the INFO diagnostics page.
On that page, turn on the CB (at the left bottom of page 1) to C19...having you stand by the bike, having your helmet on, and your wired lead plugged into the port..., press your TX trigger on the left handlebar grouping (after you set your squelch to 0...just to know you are not blanking out any weak signals, and ask "Looking for a radio check, please...working on my antenna".
Say that a few times, if you don't get a hit right away...and then when you do get a response....monitor the CB Rx 5 green block signal tally. After all of the above, on my bike, I went from a 'before touching and cleaning'...one to two green bars on CB Rx...,to a full five green bars, on most traffic and replies. If you are rather new to CB's...anytime your antenna picks up a signal that has enough gain to overcome any SQ setting (I run with around 3 out of 14, that quietens the background noise...that receiving gain will be seen on the diagnostics page. You should not be ***RIDING*** the bike when you have the Diagnostics Page on view. I suggest you take your bike, no matter where you live, to a local truck stop/centre, and while sitting there, having a coffee...display your page, be wired in with your helmet on, your mike at your lips,...pull your trigger, and ask for a "Radio Check".
When you get a response, and monitor how many green bars light up on the CB Rx bar...ask for their '20' or location. They might also be in the parking lot with you...or could be out upon the highway passing the Truck Stop. That is my recommendation to bring this great Midland radio..and a rather OEM decent, CB antenna...to life...
Cheers,
Joe
Thank you for this thread. I''m a CB guy, but knowing where to look on my new SVTC is a super help!
Quite welcome....take off the seat, remove the black lower back plate of the co-rider back rest....and just follow the C.B. antenna lead 'cookie crumbs' of the C.B. antenna lead. It starts behind that lower black panel, then one under the seat..If I remember now, the purple one, and then at the other end of the right side wiring harness, hanging off the front edge of the C.B. radio body, under the lower right faring quadrant. Take those apart and put then back together three times, then add a dollop of dielectric grease to all male and female metal connectors...and you will be, GOLD. Where, before I did this service, my C.B. 'voice' was a desert...now...everybody and their brother is talking around me...quite lively. The SVTC has a great OEM radio...it just needs a good hot 'feed' into the antenna signal input.
Side Note: If you use Dielectric Grease on all connections, this should be a one-time service. D.G. will prevent any further or-at-all, oxidization of the zinc coated male/female leads.
"The Rubber Duck, ....over n' out"... :)
Cheers,
Joe
"Break one-one: this is Victor Tango Foxtrot, 825, Southern Vermont, lookin' for a radio-check....Over."
Very good! Good call...
...BTW, it also wouldn't hurt to unscrew the CB antenna, and then screw it back down upon the brass threads three or four times. On the last time, lift the antenna clear, and then coat the threads with Dielectric Grease, and then seat the antenna base a good and snug, 'finger tight' only... Ok...NOW, it's all done...lol. I had to rethink of everything I did that morning...lol.
I'll try that as well. I have not yet made contact. In the "System Info Page" I'm still not getting any bars on the RF meter.
I also have not put a family member in one of my rigs to test the radio from across the dooryard...
Using your family member will be a very good idea. I was so disappointed in the initial performance of my C.B. radio, on the ride home from the dealer...and thought they put in a 'afterthought' unit. Well, my servicing of all the wire harness connections from the C.B. antenna, right up to the signal input connection on the Midland, dispelled that notion. At first, until my service, I stopped even trying to use the C.B. Now...it's always on...unless my wife and I are talking on the Intercom. BTW, until the next software release, if you have the Intercom ***AND*** the C.B. on, as soon as you talk to the other, you ***WILL*** be transmitting your entire conversation over your selected channel!!!! For now, it has to be one or the other as on and active. a PITA....but they know of it...and hopefully, there will be a fix. I keep C19 always on, in the background monitoring the trucker traffic on the opposing direction. When I want to speak, or her...I either turn it off, or she taps me twice on the back...and that is her signal to turn off the C.B. before she speaks, and to turn on the I.C. It's a work-a-round for now...
Green, am I to understand that you did all of the above, and still, don't have any action on the 5 bar Rx meter? If that is the case, the only thing yet to do...would be to unscrew at the very head terminal of the antenna input on the radio. But I doubt that would be the 'hold back' to a good, hot signal from the antenna. It would be the other three areas that I mentioned in this thread. Another thing I can suggest, is that you check the bottom black plastic block of the left side 'CB' antenna, and the reason that I used quotation marks on this post...is that some riders reported that the dealer, had screwed in the FM (right side from the sitting position) on the LEFT, rather than the right.... The two antennas are ballast tuned differently, so are not interchangeable, even if they will pass on a 'signal'. I'd check that. My dealer did put on the CB onto the left side of the top box...so I knew that was at least right, before I delved into why my antenna was not producing a good gain, signal to the radio. Each antenna clearly is marked as either C.B. or F.M. on that black block base.
Yes, That was the case. In the "dooryard", however, on another radio, the bars went all green. And on the radio in the other rig, the Tx from the bike was also good. I clearly heard the sound of just touching the wind-foam on my helmet's mic.
Did I "unscrew" from the base of the radio? Or "unclip"? If that connection is a screw-mount, I definitely did not "work" it - I did unclip the two purple connections I could find in the comm-block area, "worked" them, several times and then greased with something I got from my telephone company brother... I did not have anything dielectic; he said, "this will do the trick". After doing that, I was listening to "skip" from the Carolina's; I have not fired up my old, 20 watt amp in years, and I resisted the temptation....but, I believe that should confirm I'm good to go.
I think I had read a post from you during the week we were assembling the bike, so I checked to be sure the CB antenna was on the correct, port-side, post. I have also "worked" that connection.
Interestingly, after working the connections block, up on the right side of the fairing, the connectors were no longer purple. The one behind the passenger seat-back was a bugger to unclip...and it was different than the ones on the comm-block, like two micro-tabs....? I wonder if I should head back to the highway, (4 miles away) and swap the antennas if I do not get a hit, though I assume that if the wires are "crossed", the FM Radio would not work either....
I have today to try again, then I go back to work, in another state, thru Thursday....
I appreciate your help, and I'll let you know what I get later today... I suspect another issue is that there is just decreased activity in Southern Vermont....I certainly have not been using my rigs like I used to...
Rich
Discussion Starter #13
Rich
Rich, you can just read on the bottom of each antenna, whether it is the C.B. or the F.M. they are printed as such. Yes...funny as it is...Yamaha did not use 'continuity' for colors from one connection between the antenna lead out, right up to the vertical male-female on the front vertical of the radio body. They are quick connect clips, plug in's (the purple one under the seat) and then at the radio, the friction male/female. I know...weird. By the sound's of it, you got to all of them, as you have definitely identified the proper ones...AND...if you are getting 'skip'...dang, you are good to go...you probably didn't latch on, to anybody within 1-3 miles from your bike's '20'. If you are getting atmospheric skip...***YOU'RE DONE***, lololololol! Good to go...have fun, and yack it up, once you get 'connected'. As you know, with a lot of the Baby Boomer truckers retiring, the new ones...( you know....) have no clue, or probably an interest in C.B. comm on C19. Not the right native language....if at all, usually down channel. It is....what...it is....today. B.B's are retiring from trucking en-mass....and they **were** the C.B. Road Knights of the 70's,80's & 90's.......when C.B. C19 traffic was 24/7......
Driving from NH to to FL in '76. We're in GA; mom, sis and little brother are sleeping, dad's at the wheel talking to truckers: football comes up, and someone in a thick southern accent, says, " I bleed Crimson..."
"You went to Harvard?" says my father...
"Oh ****! Dad! Give me that mic!"
Mom wakes up, "...who's swearing! You boys get off that radio!"
Probably a good thing; the cover was blown....
Discussion Starter #15
Having a coffee...just about ready to head out...and all I have to say is: ROTFLM****A***off....LOLOLOLOLOL.. Great story...made the day!
I can just visualize that...you pitching forward for the mic... a battle of who has the stronger wrist, ensues.....LOLOLOLOLOLOLOL!
That aside, I hope you get the signal sensitivity to what will satisfy your expectations. That's the game...
Have a great day...riding or not... for you certainly are riding a winner of a bike...!
Cheers,
Joe
1 - 15 of 15 Posts
