1 - 12 of 12 Posts
2008 V-Star 1100 Classic
I’ve found a few posts on here about relocating the choke on a v-star, but none give any details. I’m wanting to remove it from my handlebars and install a plunger somewhere under the gas tank or beside the engine. Has anyone ever done this, and if so, can I get a generic plunger kit? I’m a novice bike mechanic, just learning as I go.
I think @Lanthus has moved his. Maybe he'll chime in.
Reactions: DiddyRides
2011 Yamaha VStar 650
If you know someone with a V Star 650, have a look at where the choke is on it - it's on the left side under the rear corner of the gas tank. Maybe you could use a similar setup and use the bracket from the 650?
Reactions: Jspree
Discussion Starter · #5 ·
Thanks. This is the info I was looking for. Will the 650 throttle cable fit the 1100?
Mine is from a 650 & installed like this. As you can see I put the knob into the carb cover that I have installed on the right of my bike. Probably yours looks very different, especially if you have not installed a pod kit. The choke knob could go anywhere it's convenient to mount though.
105811
105813
2000 V Star 1100 Classic. (SOLD) 2006 Road Star 1700
I did it on mine, but I relocated it to the right side of the bike since I put my air ride switch in the left side housing. I'll see if I can find some pics
As everyone has stated, get one from a 650.
105870
I flipped the stock mounting bracket over.
105871
Pretty sure that I mounted it one one of the stock breather mounting locations since I went with a cone.
105872
105873
I used the 650 cable, but I ran it around the coils, and to a small bracket on the air cleaner.
Sent from my SM-N975U using Tapatalk
I pulled the tombstone off and put mine on the left hand side. Just trimmed down the sleeve and cable to fit. Helps that I can operate it with my left hand while on the road.
106465
hi have just relocated mine to the neck cover opposite side to the ignigtion key best thing i ever did . also wiring harley switches and 16 inch apes this weekend . all the best saty upright
1 - 12 of 12 Posts
