I have Cobra Drag Pipes on my V Star Custom. They have turned blue from the heat. Can I polish them out and if I can what tecnique should I use.
JaBo
Blue pipes
More than likely, IMHO, they can't be polished up, I feel you are runnin lean, causing excess heat, may be way off here. There is lots of heat runnin stock, but won't blue your pipes, lean will. I feel if you did not re-jet with your new pipes that is the problem, just my thoughts. Ride safe.
Discussion Starter · #3 ·
Hmmm, just bought the bike. am going to have it serviced next week. What size jets should be in it ?
JaBo
Discussion Starter · #5 ·
Called around today and talked to a few service centers. They also said the same thing about runnin lean. Ok , so I ordered a Cobra jet kit and a couple new spark plugs. This thing is gonna get the carbs cleaned and rejetted before I twist the throttle.
Thanks,
JaBo
