I could have swore I've read you should get Tim's pms screws or max airs with any pod kit, but S&S says they suggest you use the stock screws. Is this correct? Trying to find a definitive answer before all my parts arrive, thanks!
Out of curiosity. Can you adjust the stock screws without taking the carbs off?
I use this tool. That is after you have removed the brass caps covering them.
