HELP!! MY 08 STRAT HAS A LOUD EXHAUST POP ON COLD STARTS.IF I SHUT IT OFF AND RESTART IT'S FINE.THIS STARTED A COUPLE OF MONTHS AGO, THE ONLY CHANGE WAS I SWITCHED FROM 89 OCTANE BACK TOO 93. I ADDED FUEL INJECTOR CLEANER,NO CHANGE.THE BIKE SEEMS TO RUN FINE,BUT I' CONCERNED ABOUT THE LOUD POP.COULD ONE OF THE INJECTORS BE LEAKING AFTER SHUT OFF.HOW DO YOU CLEAN MOTORCYCLE INJECTORS? THANKS BOB Z:confused:
I don't have an answer but will be watching this tread closely as mine just did it yesterday for the first time. Been sitting for 3 or days. Hit the start button and BANG,purr. 08 also.
~S~
Pop
Mine did it a coupla times after i had attempted to do the throttle bodies sync...I can only assume i put them really out cause i did them again and it hasent popped at start up again...So start with getting throttle body sync......
Sounds like a backfire. Since you just changed fuel and all, disconnect the battery for about 30 minutes and have the ecu recalibrate. See if that helps at all. when you start it up, let it idle for a minute or two then it'll calibrate while you're riding it for the first little bit and hopefully back to normal. Can't promise it'll fix it, but it's worth a shot and it's free.
