Discussion Starter · #1 · (Edited)
This seat has proven to be pretty comfortable so far, but I've only ridden it a couple hours at a time. After specifying, my weight (205lbs) and picking out the texture (black snake skin), the seat arrived in about 1.5 weeks. It wasn't a perfect fit, I had to shim up the front seat bracket with a couple washers to make it latch.
http://tweetphoto.com/10144717
Seat latch
My Mustang seat is a little tricky to get latched also. If I get it in just the right position it latches easy, otherwise I struggle a little. Don't know if this might be the case with yours or not. With time as things seat together you may wind up removing those washers.
Discussion Starter · #3 ·
I hope that is the case. I kept stacking washers until it latched, getting things to fit right would be nice. I didn't think there would be that much variance between bikes with the brackets & such, but I guess there is...
Mark.
