I use a product called perk, both on motorcycles and firearms. Works like a charm. Mirror finish if that’s where you want to take it
I usually just use mothers to polish. I don’t care for mirror look on guns… fingerprints… I will polish, just not to that level.
This slide was just dry sanded up to 600 grit sandpaper, no polishing necessary. Perfect semi polished machined look.
Back to the bike… I decided not to screw with Vector. I want this thing rideable. Went to the hardware store, bought stainless bolts, washers, nuts and nylon nuts. Then grabbed a bandsaw and 2” wide aluminum angle, 3’ piece.
This is what we started with, take note of where the bolt holes are in the stainless plate.
This is what I have built out to fit properly. Take note of where the new holes are.
Now, before anyone says, “well, aftermarket riser and handle bars…” this doesn’t even come close to them. This is a representation of how far I had to tilt it forward just to get the “glovebox” level. Then I had to raise it to clear the cables and the headlight because the cables in the original position were smashed against the glovebox opening. The headlight prevented it from tilting forward at all. No possible way it could have been bolted where the original holes were.
I will saw off the extra not needed to make it look a little more professional and drill the final holes in the morning to bolt the 3 plates together. There is a 6” piece of aluminum angled bolted to the stainless plate, the long piece of aluminum angle is just sitting on top at the moment.
I bolted those long pieces to the fork mounts and my two boys helped hold everything so I could get the lengths and angles right. What you see in the picture above is exactly where it needs to be. Photos installed will come tomorrow afternoon.
