i know this is a roadie issue and im sure it has been talked about over and over. but i just got done with a lil ride and had to put some fuel in i normally wouldnt. (not ethanol free) now bike sounds and runs like crap. got some yamalube ring free but i wonder,,,,,,,,,,,,, a friend of mine runs rails in ihra think some good blue fuel would do the trick??
Discussion Starter #2
nobody else have problems with carbon build up. sticky exhaust valve on a roadstar ????
Never had that problem with mine. The Ring Free is supposed to be some good stuff. I have heard that after running it thru a tank of gas, you need to change the oil because of all the crap that gets broke loose in the motor. I run a little Startron or Seafoam in my gas every second or third tank to keep things clean. Also heard that Marvel Mystery Oil is good to keep it cleaned out.
