I'm going to the dark side and I seen that supposed to be like a 195 80 15 05 Vista 1100 but only tires I have around here at the 205 80 15 anybody know if that will work cuz I know a 215 won't it won't beed to the rim
You don't have money you're going to go buy a new tire and my tire is wire showing so I need to replace ASAP
2005 V-Star 1100 Classic
15" is 15". It will fit the rim. Might be harder to get seated, but it will seat.
Maybe a moderator would be kind enough to move this to the tire subforum. Should be more darkside attention over there.
2006 Yamaha 650 V Star Classic Cruiser.
I found this interesting. It is about car tires and the size between car and bike tires. There is a difference between the rim size which you will see if you read through the information. It seems that some car tires will not fit onto motorcycle rims and by reading this you may be able to save some money by not buying a tire that although is the same rim size will still not fit the motorcycle rim. Just click on this underlined link Car tire on 650 V Star?
