1 - 2 of 2 Posts
Hi folks,
was looking at getting a tachometer for the XVS1300A deluxe on ebay and found some pretty cheap ones but some have 3 wires and some have 5 wires would anyone care to let me know which one I should purchase or doesnt it matter ........ thank you :smile:
I did find the article at the wiki and it wasnt that helpful for me.....
Most aftermarket Tachs are made for dual fire ignition systems a.k.a Harley. This means the plugs fire both on the ignition and exhaust cycle. Our bikes use a more modern single fire system. Most of the tachs will not work unless you use a Tach adapter. Without a tach adapter, your tach will read approximately 1/2 of the engine RPM. The Barons Tach adapters are known not to work very well and have jumpy needles. I know this from experience as well.
Cobra makes a single fire tach but it is pricey. The Wiki page you referenced does have a link to making your own tach adapter and it works fine.
When I had my 950, I bought a Drag Specialties Tach https://www.denniskirk.com/drag-specialties/mini-tachometer-2211-0032.p407394.prd/407394.sku
And made my own tach adapter and it worked great!
1 - 2 of 2 Posts
