2009 xvs950 midnight star (vstar to the usa market)
Horn and headlight has decided to stop working , checked headlight fuse all ok (no idea what fuse the horn is on) switch looks fine
any ideas or common occurences please???
do you have a volt meter?
check the bulb and make sure its not blown
also check the ground wires for the light and horn, they might goto the same place and be loose or corroded.
spentall day saturday with multi meter and traced it to some bad wiring under the tank/seat 0:)
