Mystery - an '14, 950 with 600 mis. I re-routed brake, throttle lines to accommodate risers. I removed headlight assembly for access. Buttoned everything up and now CEL remains on, code 22.
Code 22??? I think that's the air intake temperature sensor code. But all I touched was headlight area along with removing brake master cylinder for rerouting.
Any ideas about throwing a 22 code?
Thanks farmall. I saw that post when I searched forums. I doesn't help me in locating air temp. intake sensor.
I can't imagine why just moving the headlight assembly out of the way would throw a 22 code unless I pulled hard enough on the loom to effect the sensor connection.
Thanks anyway.
Fixed it!
The intake air temperature sensor is immediately behind and below the headlight. I did disconnect when moving the head light assembly out of the way. Just a simple reconnect and the CEL code 22 is gone.
