1 - 2 of 2 Posts
Discussion Starter #1 (Edited by Moderator)
Hey guys! So I picked up this 2000 vstar classic with Vance and Hines pipes custom seat brand new tires and battery for 700 knowing there was a knock coming from the engine. I figure I am going to have to swap out engines but I'd figure I'd let you know what going on. I will post here and in the technical section too!
So the engine is knocking and I pin pointed what cylinder (rear) the front cylinder is getting no spark which has the rear cylinder doin all the work and running really hot and I suppose knocking.
I guess my question is, is the reason the rear cylinder is knocking is because of a piston being over worked. Maybe the PO didn't realize it was running on one cylinder? Or was it just always ? Thanks guys!
1 - 2 of 2 Posts
