1 - 11 of 11 Posts
I have just under 700 miles on the bike, so did the first oil change this weekend. Did both engine oil and transfer case oil. Used a trick I read on here about using lumber to get the bike up on for the add'l clearance for the oil pan. Used a couple 2x6's cut with a 45 for the tires, worked pretty good...thanks! The oil change went pretty well, but the filter was a real bitch to get off. I used a rubber strap wrench to get it off, just about couldn't get it as it was super damn tight.
The transfer case, though what seems like a major undertaking just to get to the plugs, went pretty well all things considered. I ended up spending 4 or 5 hours doing the entire job as I am not a bike mechanic, though I typically do most of my own mechanic work. I found a PDF copy of the service manual online for free and that was actually a great help if you've not used it before. It goes step by step what all you need to do to remove the exhaust (which is a must to change the transfer case oil).
I used Valvoline 20W-50 dino (4-stroke) and Valvoline 75W-90 synthetic for the transfer case.
Fortunately, I've got a shop now where I can make a mess but not lose parts in the gravel (like I've done in the past).
I truely dread when i actually get a liner and have to do these fluid changes.
It's not that bad. I'm no mechanic either and I did oil and t-case in about 2 hours. I didn't completely remove my exhaust to get to the t-case either. :)
Man, I envy you...that's an awesome workshop! I wish I had all that space in a well lit climate controlled environment to work on my liner. On the other hand, I did my t-case and oil change recently but took a shortcut on the t-case which did not require nearly that much wrench turning. The alternate method is pretty well know and written up in this forum. Ride Safe.
Nice job,well done. Hey there is too something wrong with your shop,I only see one bike and no working refreshments lol.
Clearly, you missed the Corona bottle on the table. Actually, it's not Corona, but a buddy of mine went to "Gallaghers' Where U Brew" in Edmonds, so enjoying one of his creations. Also, the GSXR is off to the right in the first pic, out of the FOV.
My bad I should have spotted that without my glasses on. Wouldn't mind see n a oic of the suzi.That was one hell of a bike in its day.
Well, ask and you shall receive...
That is in great shape, nice rocket. That's vintage rice at it's finest.Too bad you couldn't keep it.
1 - 11 of 11 Posts
