1 - 11 of 11 Posts
Please make life easier for anyone who has to wrench on the bike.
It's going to be very hot the next several days, I figured I'd take the windscreen off.... Yeah right.
The previous owner installed and HID, and bolted the unit (ballast, igniter?) to the cross beam of the windscreen.
I couldn't take the frame off without removing the HID unit first. Closer inspection finds the unit is bolted behind the windscreen bag. Neither the windscreen bag or HID unit can be removed without removing the windscreen from the frame.
Removing the windscreen from the frame is no big deal, with the frame OFF the bike. It's a major PITA with the frame on the bike (it's almost impossible to get to some of the cap nuts on the back side).
But I can't remove the frame because the HID ballast has no quick disconnects, and not enough cable length to unbolt the frame and lean it forward.
So, get the windscreen off the frame (about 45 minutes), then start disassembling stuff.
SWEET BABY JESUS, if you're going to add stuff to the bike, use METRIC!!
I had SAE and Metric sockets, Metric and SAE allen wrenches, star wrenches (!), Phillips and standard screwdrivers to remove all the various nuts, bolts, and screws.
After all the stuff was off, the HID is a rats nest of units, resistors, relays, and other stuff.
OK, lets see how it's wired and where we can hide stuff. I went to open of the headlight bucket.
THE LIGHT BAR BLOCKS THE BOTTOM BOLTS of the bucket!
I'm done for tonight.
Discussion Starter #2
I'm better now. I have 200 miles round trip to a meeting tomorrow. Went out and zip tied all the HID stuff down, put the top bolts back in the headlight bucket.
I am taking the bike tomorrow! Everything else can get fixed this weekend.
Sounds like some Wind Therapy is need post haste!
Yeah, heading out in a few minutes. 200 miles of two-wheeled bliss.
I was a bit torqued last night. I know nothing ever goes as planned, but 2.5 hours to take the windscreen and frame off the bike was a bit much.
This weekend I'm pulling the HID and putting in an LED. There's just too much junk to hide with this unit.
after i had to split the cases to install a 5th gear set i changed every bolt to allen, even the shock and eng mounting is allen now, teardowns are lightning fast
Nice! I think I'll go get a set of various sized allen bolts, and do the same. It'll easier to use the electric screwdriver and allen bits to disassemble and reassemble stuff.
I have removed all the stuff connected to the windshield frame, and it's all coming off the bike. I like the HID, but the unit he put on there takes much more room and has more black boxes than there is space to hide things.
the new H4-9003 led conversion bulbs work better in reflector headlights check out the lumileds zes H4 it has a cutoff hood on the low beam and adjusts laterally and rotationally to get a good focus it has a reversible heat sink
Thanks for the heads up, I will order one now!
Finally tore down the rats' nest of wires, splices, solders, taps, fuses, boxes, relays, and shrinkwrapped factory and add-on wires and got everything back to stock.
WHEEEEW! That took about 8 hours total, when the original objective was to pop off the windscreen....
But from here out, it's four bolts to take the windscreen off and on.
The last two bikes I purchased were used, and the first thing I had to do with both of them was go through the additions the original owners had put on and redo them to clean up the wiring, ss fasteners, and just pull some of them off totally. The things some guys do (and some dealer's mechanics) really make me scratch my head as to why it was done that way. I guess quickness wins out, no matter how sloppy it is. As long as it works.....
That's why I'd never make it as a mechanic. Too slow, too deliberate.
Keep up the good work pilotalan! At least WE know the job has been done correctly, and won't have to be done again.
"Hopping off the soapbox"
The last two bikes I purchased were used, and the first thing I had to do with both of them was go through the additions the original owners had put on ... At least WE know the job has been done correctly, and won't have to be done again.
Thanks Dave. The next thing is to clean up the wiring and the add-on accessory fuse block under the seat. Each addition has an inline fuse holder. A block with fuses built in (like the Kuryakyn unit or similar) will simplify and reduce the amount of space the current set up takes.
1 - 11 of 11 Posts
