New Cobra Tach installed
The tach arrived last Friday. Installation was very easy, once you figure out which harness is the left turn signal.
My only grip about the Cobra tach (excluding the $240 price tag) was the length of wire running to the coil. It is about 6" too short. The wire has to run from the headlight underneath the gas tank to the coil. The wire is just long enough to make it but has to be installed in the shortest route, which puts it right on top of the engine. I was able to stretch it so the wire doesn't touch the engine, but an additional 6" would have allowed me to run the wire using the same supports that all the other wires to the coil use.
The tach looks good and has a very bright backlight. So far very pleased.
