1 - 13 of 13 Posts
question. when referring to fork tube circumference or size or whatever, which part are people measuring? most of us have telescopic fork tubes which are mainly 2 parts. the upper part contains fluids/springs and so forth and is larger than the lower part of the tubes. so there's actually 2 different measurements for the tubes. so which is measured? what size is it really?
i'm looking at replacing my turn signals and want to make sure i'm getting the correct size.
in additional this, what is actually measured when talking about fork tube sizes? for instance, i know that i have 41mm fork tubes on my v star 950. but what, exactly, is 41mm long?
Banned
Hey Bevo, I.m pretty sure forks are sized by the outside diameter of the inner fork tube. In other words, your fork seals will have an inside diameter of 41mm and therefore will fit inside the outer tube which will have a different and larger inside and outside diameter, like 55mm or something close to that.
I don't think your 41mm spec size of your forks will coincide with how turn signals are sized. My guess would be they are sold to fit the outside diameter of where you want to mount them. In the case of a stratoliner/roadliner, turn signals may be mounted to chrome covers that dress up the outside of the fork tubes. For what you are doing, I would simply measure the diameter of where you want to mount the turn signals and use that measurement to order them.
The easiest and most accurate way to measure the diameter is with a set of calipers. If you don't have those you can wrap a cloth tape ruler around it and take that length (girth or circumference) and divide it by 3.14. If your cloth tape measures in inches you will have to convert it to millimeters if that is how the turn signals are sized.
yeah i measured the diameter already and it's way over 41mm, both upper and lower part of the tube. 41mm is pretty small, a little longer than the length of the tip of your thumb to your first knuckle. so i don't see how that measures anything on the outside. but these sites are sizing out the LED clamp signals by the size of your fork tubes and i want to make sure i'm picking something that clamps around the upper stanchion near my current turn signals. the diameter of my lower tubes are around 60mm. i just want to know what is actually measured and i can't find anything online.
http://www.chromeglow.com/catalog.asp?prodid=670484
Banned
Yep, 41mm is just a tad over 1 1/2 inches. Go with the diameter you measured at the place you want to mount them and place the order.
Banned
By the way, how exactly do mount them to the fork? Do they spit into halves and you reconnect the two halves around the fork??
Might make sense to give them a call.
I replaced my stock turn signals with small chrome bullet lights. Used chrome Kuryakyn clamps in 41mm size to mount them to the fork tubes between the upper and lower triple clamps. I do not know what size your tubes are but most I have seem for metrics in the Star line are 41mm. They are hinged clamps that simply wrap around the for tube and pinch into place when you tighten down the light mounting nut. Same principle as you wouldsee on a crash bar clamp. I posted photos on here somewhere of my mod. I will find and post a photo of mine.
Here is an Ebay sale for the clamps I used. VERY NICE AND CLEAN!
http://www.ebay.com/itm/KURYAKYN-4014-CHROME-39mm-41mm-P-CLAMP-/120848603786?pt=Motorcycles_Parts_Accessories&vxp=mtr&hash=item1c23235a8a
thanks Dirk. that's kind of what i was looking to find out. i want to make sure these things attach to the upper part of my forks and not lower. but i'm still leery of not knowing what exactly is 41mm or what they actually measure on the fork tubes.
the kind i'm looking at are either the more expensive kind that is an aluminum bracelet that clasps onto the tube, or the less expensive which are just the plastic sleeves of LEDs that are applied with 3M adhesive and zip ties.
Banned
Geez, I dunno Bevo, I think your bike has the chrome covers over the fork tubes up there between the upper and lower steering head clamps. I'd bet you a coffee and a donut that is a bit bigger than 41mm.
Hey Dirk, can you measure the actual diameter of that place where you have the Kury blinkers mounted?
Hey dirk how hard is it to take the light bar off of the 1100? I have been wanting to remove mine for a cleaner look,and the fact it is a little broke does not help.
Never had a light bar. Sorry. Just stock headlight and rubber mounted turn signals on my 2003 1100 Custom.
Oh, well they have two bolts to remove. One holds it tight to the lower triple clamp and the other is to hold it tight around the fork tube. Remove the bolts, unplug your wires inside the headlight housing and simply spread the rubber clamp to remove it from around the fork tube. Piece o' cake
1 - 13 of 13 Posts
