I was looking at the Memphis shade fork deflector mounting kit for my strat 2014 deluxe, but I' m not sure if they will fit. Is there anybody with a strat 2014 who has them?
I tried to install them on my '07 Strat-non delux. I do have the Memphis Shades Batwing Faring installed. Should be the same. The problem I have is that they will not work with the Yamaha big bar engine guard.
They interfere with the engine guard when trying to turn the handle bars to lock to lock position.
If you still have questions, I'd contact Memphis Shades.
After heading out to the garage to check thing to get my head straight, I remembered that the interference problem is cause mostly by the passing lamps I installed. When they are installed, the turning lamps are mounted below the passing lamps and closer to fork tubes. With the turning lights dropped, the deflectors have to be mounted in a way where they contact the bar. So with that said, I don't know if there would be a problem with factory placed turn signals, big bar and the Memphis shade fork deflectors.
