1 - 2 of 2 Posts
Anyone know of where I can get LED bulbs for Stratoliner stock front signal light housings ?
I would think the one in this LINK would work. Yamaha uses their own post pattern on their bulbs. I believe, what ever LED 1157 bulb you choose, you will need to grind off the post nearest the contact end of the bulb and then insert the bulb with the remaining post in the up position.
I believe that if you get a longer bulb, you will encounter interference with the lens.
1 - 2 of 2 Posts
