It would seem to me that you must have a float inside your carburator that is stuck open. This would allow the fuel to flood the carburator and come out the drain line that you are talking about. I would turn the fuel off at the tank, drain the fuel bowl, and then remove the fuel bowl to inspect the float to see just what is causing it to stick.
Ride Safe-Be Happy
Ride Safe-Be Happy
