1 - 11 of 11 Posts
V star 06
I have a v star 2006, for about a week when using my motorcycle it reaches a point where the pump sounds very loud and with the same effect as if the gasoline system had air
In that case, I have to remove the tube from the fuel inlet of the pump, remove a little with the air they have and then it works normally.
What do you think could be the problem?
As extra information: the fuel pump and the fuel filter are new
Thanks for your time
Or a pin hole in the fuel line, also a crack in petcock .
V star 06
Discussion Starter · #4 ·
the petcock is new, now what I think is that the filter is blocked although even when the pump does not stop working, the motorcycle can be used normally and without gas drops I filled the full tank of the motorcycle and it has not been done again, could it be a symptom?
It sounds like a very small pin hole in a line or the pressure cutoff in the pump is going bad and just shutting it off is resetting it.
V star 06
Discussion Starter · #6 ·
It sounds like the pump never reaches the pressure, but it works fine
What I'm afraid of is that I'm left with the bomb of working without stopping
i just looked at mine on the 1100 because i don't thing its working right, its on the lower frame and all the connection in the boot cover were full oil and dirt, i took the hoses off to see if it pumps, it did, cleaned the connections and put electric grease in them, it started first hit of the button, before it wouldn't start, plus i ordered a new one from ebay with the correct plug, maybe that scarred it into working.
Administrator - "Loose Nut" - Bandera, Texas
2001 Vstar 1100 Classic (sold), 2006 HD Electra Glide Ultra (totaled) 2006 Vulcan 900 (current)
Simple fixes are the best!!
The way the tank is built on the VStars it will only gravity feed half the tank , so you have to have a fuel pump to pull the other half of the tank out.
1 - 11 of 11 Posts
