Hello everyone I need help in my bike it's a v classic 650, it stop on my way home so I towed it, I start to figure out what's wrong with it and I ended up in fuel pump relay after testing any posible defective parts Ive checked fuses it's ok, the carbs is ok and now I'm looking for the fuel pump relay I can't identify which one is the fuel pump relay, anybody might help me to identify which one is the fuel pump relay, hope to hear from somebody about the fuel pump relay thanks and have a safe riding everyone...
Here is a link to the service manual. The fuel pump trouble shooting is on page 7-38.
Not sure of the location of the relay but I don't believe it is in the relay box. I believe it is in the wire harnes under the tank on the left side.
The book says to remove seat, stering sidecovers, Battery cover, and fuel tank before troubleshooting. So the relay is in that area.
http://www.paulmilner.com/yamaha/handbuch/VSTAR_650_MAIN_MAN.pdf
Hi, yeah i follow the link to trouble shoot the fuel pump by connecting it to 12volts battery and there's no flow of fuel from my fuel pump, and I'll try to buy another fuel pump but I read that somebody try to buy from yamaha and it will cost him $300 for it, which I can't afford to buy one, so I will try to use the airtex e8016s which the other member post that he uses that one in his bike and it works, any idea if it will also works on the 650 because his is a 1100, by the way thanks for the info that you gave me I appreciate it, I hope this one will work...
