1 - 15 of 15 Posts
Just thought i would give a FYI thread that might help somebody out in the future. I have a 09 star 950T with around 26,000 miles on it and around august of last year, i noticed a squeal that sounded to be originating from the rear tire, so i figured rear axel bearings. After i pulled the rear tire off and inspected everything, i couldnt really find anything wrong that would lead me to be the culprit. The bike still being under an extended warrenty, i put it all back together and took it to the dealer. After keeping it for a week, way to long, they called me and told me that the technician drove it but couldnt hear the squeal and they didnt want to tear into it with fear of not finding anything and warrenty not covering it, but did find that my belt was too tight and made proper adjustments. After getting it back, it seemed that fixing belt tension really helped for about a week or so, but then it came back. After a bad winter and not riding it much, i finally got it back out and on the highway and it progressively got worse with the squeal now sounding like it was coming from the front drive sprocket. I took it back in a couple of weeks ago and got a call to come talk to them. The service manager said they took it down the highway and could definitely hear it now. They put it on the lift and let it idel in gear and could see the front sprocket had a wobble to it. After tearing into it, they found that my primary gear was warped. They said the bad news is it is about $1100 in parts and the extended warrenty doesnt cover sprockets or belts, which it needed among other things, but the good news is they talked with yamaha and yamaha said they would cover all the parts, i would just have to cover labor. It worked out in the end i guess. Just thought i would share in case somebody else has the same problem in the future.
in most of the cases i've seen with the 950 developing a squeal, including mine, it's been a belt issue needing replacement. i'm with Havoc that the overtightened belt may have caused the problem, and you may be needing a new belt soon anyways even though the initial problem of the sprocket gets resolved. the belt issue has been occurring around the 30K mile mark which is right where you're at. so have them take a look at that.
Was it easy to see? I am thinking of buy one and he has replaced the rear bearings but thinks there maybe more wrong.
I'm curious what parts had to be replaced other than the sprocket and belt. I'm currently dealing with a wobbling front sprocket. I initially assumed the squeak was the belt so I ordered that. I decided to start the bike since it's been sitting for awhile before I threw on the new belt and that's when I noticed the slight wobble in the sprocket. I'm afraid to replace just the belt now and run the risk of ruining a new belt (they certainly aren't cheap).
Ah Now this can't be good, rode off Wednesday to a job interview, and half way there a squeal developed, the last belt adjustment was by the technician when they replaced the rearend, swingarm all the way back because the axel bolt froze up in the wheel, this fell under my extended warranty. Now the dealership that did the warranty service has now changed hands and they say they're not responsible.
i would find out what it is before assigning responsibility to someone. whatever is causing your squeal may not be related to the previous repair. and you don't know if it is because the belt was overtightened, that was just one school of thought.
Squealing belt issue resolved
:(I took my VStar in to D&D Cycle Shop in Winder, GA, on Friday, they checked the belt & drive gears, the belt was to tight,:) they mounted a dile indicator and and found drive sprockets within limits.:D
So an over tightened belt can cause a squeal, or chatter. Over tightening the belt can also cause the sprocket to flex enough to cause the belt to track out to the outer edge and chaff the edge of the belt.
I had an experience with the V Star 950 belt drive system that I documented but, I cannot attach the file here because of the size limitation on the forum. :( If you are interested please PM me with your e-mail address and I will send the document to you. Augie
a buddy of mine claims his mechanic found the cause of his belt issue:
"check the front flywheel. it's behind a guard and there's no need to check it when adjusting the belt. the bolt [should] be tight but the washer behind it loose. only the locktight has been keeping the flywheel from flying off. tons of belts have been replaced but the issue and the noise remains."
We've had lengthy discussions about this for our 1300's in the past, and it is widely understood that the belt tension from the manual is WAY too tight and will damage stuff. A local Yamaha mechanic said it is better to have the belt a bit loose than a bit tight. I don't remember what the numbers are, something like 17mm deflection at 10lbs, not 5-7 like the manual says. The critical part is to make sure it isn't so loose that it could jump off. I don't even use a gauge now. I just make sure there is some slack in the belt.
Hmm? Confused. :confused:
1 - 15 of 15 Posts
