1 - 19 of 19 Posts
Hi all, just to let know check the two Philip head screws on the bottom of the gas cap. I bought a used 1100 V Star classic with 42000 miles on it. It came with a new gas cap and key and I did not much think about it. Until I kept hearing a strange noise when I stopped kind of hard. So thinking about it, just for kicks and giggles I stuck a telescoping magnet in the tank and I pulled out a washer, a screw, and two small springs. Ok fast forward, it's parts of the bottom of the gas cap. I had to drain the tank and remove it and use the magnet and a grabby thingy to pull out the rest of the steel and pot metal pieces. The hardest part was getting the little stainless steel ball bearing out. So apparently the previous owner had a screw loose or two. Just saying :D
This seems to be a problem with many of the older 1100s. Mine is an 08 model, and the screws remain tight (knock on wood) although knowing that this has been a reocurring issue I give them a look at each fill-up.
My grandson has an 06 model and the guts of his gas cap fell into his tank while he and I were on tour this summer. We used duct tape to hold his cap on during the remaining portion of the trip, and when he got home he used a magnet and extended hemostat to rescue all the lock parts from his tank. He used lock-tight on the screws when he reassembled the cap.
I'd say there is a blessing hidden in all this that now you'll be able to use the single ignition key to open your tank rather than having two keys on your ring, one for the ignition and one for the tank cap.
Incidentally, I checked on the price of a replacement locking cap for his bike, $118. This alone made it worth the time and effort spent in fishing the parts out of his tank.
I'm glad you could recover the parts and save some bucks. I don't know if the dealership where I bought the bike knew about the parts in the tank. I guess it would depend on what the previous told the dealer. But I got a baggie full of spare parts.
I am also missing a screw from the gas cap but I don't know if it fell out somewhere at a gas station or if it's inside the tank. Did you hear the screw in your tank? I shook my bike from side to side and I hear nothing but that may not mean it's not in there.
I could not here any thing when I shook the tank side to side. I only could hear the parts move to the front when I did a hard brake. I had a whole lot of parts in the tank so they made a lot of noise. The best way to check is to use a telescoping magnet pen (they are pretty cheap) and fish around the tank. Less gas the better you might see it on the bottom using a flashlight. I hope you find it good luck.
I stumbled on a sticky thread about this about 2 weeks ago. Sure enough, I went outside and mine were loose as well. 2006 1100 custom. I always wondered why the gas cap seemed to wiggle so much when it was sitting on the gas tank, after tightening the 2 screws it feels much more sturdy.
mine came apart about a month ago on my 650. Lost one screw in the tank. I could hear something rattling but didn't know what it was till i stopped for fuel. thank God for the small tool kit. Going to take the tank off before i put it away for the winter to retrieve the missing screw i can hear but can't see it to grab it with a magnate.
If you can't fish it out with one of those telescoping magnets, you might be able to remove the petcock and drag it over to the hole with a strong magnet from the outside.
Finally remembered to check mine yesterday while filling up. Sure enough they were both loose. Got home and added a little Loctite and now, like uTHINKSO said, my cap fits much tighter. No more wiggling and wobbling. Go figure. :D
Almost two years ago I pulled for painting, among other parts, the fuel tank. Upon removal I found a machine screw inside the tank. Hmmmm! Now I know where it came from. Interesting that the second screw, while loose when I checked today, was at least still there. I also now know why I sometimes struggled with the cap alignment from time-to-time.
By any chance, can someone provide a part number for a replacement screw for an '04 1100 V-star Classic?
Thanks!
Glad I read this post
Yesterday as I almost always do, I read the forum, I have an 06 650 Custom, I went out and removed the gas cap, low and behold BOTH SCREWS WERE JUST ABOUT TO FALL OUT.
I removed one at a time and put locktite on each and tightened securely.
Been reading the forum ever since I got my xvs65V and posted several times.
Needless to say I will continue to read daily for info just like this.
Thanks again for the post.
Discussion Starter #14
Tripilot
Thanks!
Tripilot, send me your mailing address and I'll send you the extra screw I have for the gas cap I pulled out of my tank.
[email protected]
I got my Vstar 1100 almost five years ago. Anyhow, I recall reading in the old KB about this issue soon after I bought it. I loctited mine in immediately.
Good thing about having a Vstar is all the info out there to be gleaned. This bike has a loyal following so there is always something to be learned.
This should be a sticky. For those who don't frequent other sources of information.
If you have an 1100 and don't use the wKB you are really missing out. It's got everything...including the gas cap screw warning in bold red letters as the 1st item of most importance in the "New Owner" section....
https://sites.google.com/site/vstar1100kb/home
Use it now....as it "may" soon become restricted to only members of the "V Star 1100 Riders" forum on Delphi Forums who did all the work to put it together and still host the site.
One of my screws has fallen into the tank. What screw should I use to replace it. Any specifications ? I own a Vstar 650 custom 06 model.
Someone here may know the screw specs but if not just pull one of the remaining screws and head to your local hardware store and you should be able to match it up.
1 - 19 of 19 Posts
