Can someone out there help .gas Leak don't know where is it coming from what can I do to fix . Bike runs Good Only when hot it idles high It's a V star 1100
Sent from my SM-G950U using Tapatalk
the crankcase vents into the air intake box. pull the air cleaner and see if there is a little oil in the housing. 'if' it's blowby check the oil the level should be closer to the bottom line in the site glass.
Thanks I'll look at it
Can't say it's the same but, the flange self joining the top half to the bottom half of the tank leaked on mine. Couldnt see it until you removed the speedo and then not unless I had more than half a tank. Before you assume a fuel leak, does the garage smell like gas when left overnight? Doesn't take too much gas to smell the place up.
Sent from my SM-G930V using Tapatalk
