1 - 19 of 19 Posts
I had a strange issue with fuel overflowing out of my tank yesterday.
I went on a a couple hour ride with my GF. The bike ran great. It was 32 degress celcius. When I stopped for gas, I filled it up to the usual spot, which is right when it hits the splash guard (dunno what it's called) at the bottom of the filler's neck. Sometime I squeeze and extra bit in until that splash guard is 'just' covered. You know, to maximize my range. :p
Then I parked it while my GF went inside to use the bathroom. While I was standing there in the hot sun baking, I noticed I could smell gas and when I looked over at my bike, I could see fuel flowing out from under the gas cap and down the side of my tank into the engine area. I quickly took the gas cap off to see if it was a venting issue and would stop, but it didn't, it just kept (over)flowing up and out. I ended up using a spare rag I had on hand to sponge a decent amount of fuel out so it would stop flowing out and running down all over my bike. That worked, but afterward, I could still see what looked to be air bubbles pushing the fuel up and trying to get out. Luckily, I had sponged out enough fuel that it was no longer bubbling up high enough to overflow out.
I waited until we were ready to leave before putting the gas cap back on, and it was incedent free for the 2 hr ride back home.
Any idea what caused this? Excessive heat combined with filling it up too high?
Here's a pic from the Ride
Google says:
Gasoline or petrol is a fuel, derived from petroleum crude oil, for use in spark-ignited internal combustion engines. It has an initial boiling point at atmospheric pressure of about 35 °C (95 °F)
With the gas tank sitting on top of a hot engine, in the sun, you were experiencing the fuel boiling. You were already at 32 degrees C ambiant temperature. It's common in Texas, I never fill my gas tank all the way full because of this. In some situations you will get vapor lock, (vapor from boiling gas enters fuel line) and creates a none fuel flow issue.
Google says:
Interesting. That makes sense.
I've never experienced this on my previous bikes (one was carbed, one was fuel injected). The fuel also did'nt feel hot at all when I sponged it out with a rag. In fact, it felt cool to the touch?
Edit: Maybe it felt cool because i was touching the fresh fuel at the top of the tank but it was the existing fuel that was boiling while mixing and forcing the fresh cool gas up and out?
I think its more of a case that you filled the tank all the way, nearly to the brim, with gas from a tank in the ground
the gas coming out of the hose could have been very cold, maybe 5C
when you filled the tank with the engine hot, and sitting in the hot sun, the gas quickly warmed up and expanded, forcing it out of the cap
I was not aware that gasoline "boils" from 100F to 400F - the definition of boiling is when the fuel vapor = 1 atmosphere in an "open" container.
If the container is sealed the pressure will increase as the temp increases, raising the boiling point.
I guess it could be a little of both.
I never fill the tank all the way to the brim unless Im riding and know I will be going at least another 20 or 30 miles to pull the tank down a few quarts, before I stop.
Now that I typed that out loud, that is not good either, because I might intend to get on the bike and ride another 30 miles, but who knows, something might happen a mile down the road causing me to stop... I guess I should stop doing that.
Filling the tank all the way, and then parking the bike for the day is the worse case situation.
Wow. I've heard of and seen fuel dripping out of the vent hose before but not coming out from under the fuel cap. Which make me wonder if your vent-system is working. This almost sounds like a demonic possession!
Eastern Washington state is very similar to Texas. I've also filled mine up and then it sat in the sun while I exercised my butt muscles in much needed walk/stretch periods. Not once did it so much as hiccup in 90+ degree weather. How much is 32 degrees C in real temperature (F)?
thinking about this some more, if you fill the tank up to the bottom of that tube on the fill inlet, and if the tank vents thru the gas cap
then when you stand the bike up, if the fuel completely covers the bottom of that filler tube, even if there is air in the top of the tank, as the air and gas heats up, and the pressure vents out the cap, then the gas will be pushed up that tube quickly and out the gas cap, if the pressure has no where else to go.
is there suppose to be a vent tube somewhere else on the tank, at the highest point?
I have to look at the tank drawings now....
looked at the exploded tank drawings on bikebandit - Ive had the tank off my 650 and Royal Star, there are no tank vent tubes that Im aware of - so the tank must vent thru the cap
so yes, unless that short tube that extends down from the filler port has an inside opening near the top, it would tend to push the fuel up out of the cap when the entire lower end of the tube is completely immersed in the fuel in the tank....
I have been getting away will filling my tank all the way to the brim for several years now.
Google says:
Gasoline does expand and contract a little depending on its temperature. When gasoline rises from 60 to 75 degrees F, for instance, it increases in volume by 1 percent while the energy content remains the same.
LOL. We are metric up here but some old schooler's still use F.
I too suspected venting, but the only way in and out of that tank is the petcock or the gas cap. I know because I've had it off several times and even had to clean rust out of it. When i removed the gas cap, it kept on overflowing so that doesn't seem to be the issue. The petcock is brand new.
I've also been filling like this since I've had the bike, which admittedly isn't that long. I've only put about 2500kms on it since I got it. However, considering I have to fill at just under 200kms, that's a lot of fills and never had this issue before.
It has to be heat related though. I decided that going forward, I better be ready to immediately ride some distance if a) It's hot outside and b) I continue to fill it right to the rim like I have been.
Otherwise, I'm at a loss. Also, i never really thought about the fact that it's sitting on it's side when I'm filling it to the brim. Then when I stand it up...hrm...fuel must be touching the gas cap at that point. Not a huge issue since I usually then pull out and put some kilometers on it bringing the level down. However, in this situation, I just moved it to a parking spot and it was still on it's side stand when it started puking gas out.
Google says:
It has to be this Les. Hot day, hot bike, cool gas combined with filling it up as far as I could...and it was a station in the middle of nowhere thus, questionable quality fuel. Expanding gas seems a more plausible explanation to me than boiling gas.
Or combination of both. It used to be very common for vapor lock caused by fuel boiling before efficient fuel injection and return fuel lines. Guess I'm old enough to remember those days.
Discussion Starter #12
Interesting:
https://community.cartalk.com/t/myth-or-real-hot-day-and-full-tank-of-gas/72874/7
I like this reply:
"Yeah I’ve done this too.
Bought an '84 Honda V45 Sabre in Nogal NM. Drove it home to Pittsburgh. Somewhere around Shamrock TX, I filled it up then did laundry for an hour or so.
When I came out, gas was seeping out of the overflow vent in the cap onto the outside of the tank.
OP, if you can schedule your fuel stops such that you drive 10 mi or so right after filling, you’ll burn off enough gas to handle any expansion."
Thanks gentlemen. I learned something new (again) today from this board.
Discussion Starter #14
page 3-7 of your owners manual shows proper filling of a gas tank.
The photo on the page seems to match what I did...but I guess I did it too much. Funny...there is also a warning on that page:
"Do not overfill the fuel tank, oth-
erwise it may overflow when the
fuel warms up and expands."
LOL....
I just thought i would post that because apparently i have been over filling for almost 50 years. My old vtx i had to sit on and hold it upright so i could get a full fill.
I learned something new to day so i will go to work and ask for a raise.
If you want to prevent this from happening, stop filling the tank, while you are sitting on it, holding it upright.
... i had to sit on and hold it upright so i could get a full fill.
more important than not over filling your tank, dont sit on the bike while you are filling the tank
you are holding the bike up with your feet
the open tank is between your legs
if the fuel spills on the hot engine, or a spark ignites the fuel, you got no where to go
you will drop the bike when you jump off, with the gas tank open and burning...
I also keep my left glove on while filling the tank - if it does spark and ignite I might be able to extinguish the flame by putting my gloved hand over the filler opening (cutting off the air supply)
Besides all than, when I stop for gas I pretty much need to get off the bike and stretch my legs...
Besides all than said:
I totally agree that is why i am glad the vstar has a filler opposite the kick stand. Filling the vtx sucked. The filler was in the middle. I could get about 1/2 gallon more by holding it up. With the 1800 it easn't very efficient. I am glad with the star i can get off to fill it.
talking about this at work and I think we figured out what was going on.
like Lesblank posted, gasoline starts to boil at about 100F, and since its an organic hydrocarbon it will continue to boil up to 400F
how fast it boils depends on the pressure of the vapor in the container
the gas cap vent on the bike must allow some pressure to build before it vents out
so: you filled the bike up with a hot engine then parked it in the sunlight. The tank and gas heated up, expanded from being cold in the underground storage tank, started to boil if the temp reached 100F
and then when you saw it over-flowing the gas cap, and removed it, you released the pressure that had built up in the tank, and it was like shaking a bottle of warm Pepsi then opening the bottle
the drop in pressure made it boil out more vigorously
1 - 19 of 19 Posts
