1 - 20 of 43 Posts
So the other day took 2001 v Star 650 out for first ride of the year. Smelled gas, got a few miles, determined it was coming from the bike, tried to get back home, bike died, towed home , now trying to fix. Removed tank and breather box from top of carbs , took bowl off front carb expecting to have stuck needle valve. Float and needle valve came out with no problems so that needle did not seem to be stuck. Put carb back together, put breather box back on, and now when I tighten the clamp that holds the breather box to the top of the carb throat it pushes the rubber boot up and off of the carb. When I first removed the breather box it came off with no problem, I did not even have to loosen those clamps which didn't seem right. I'm pretty sure that's where the gas was leaking out of ...where the breather box connects to the top of the carb throat as far as I could tell at the time. Any thoughts?
if the float is stuck low in either carb float bowl there is an overflow tube that goes down just above the top of the crankcase on the right side of the bike.
If the tube is in place and not crushed it lets the fuel leak out where it wont hit the exhaust and combust into flames
If that tube is pinched off I guess its possible the carb could fill to the top with gas, but I think it would also fill the cylinder with fuel, ruining your oil by dilution.
you said you took the front float bowl off, it could have been the rear float that was stuck
those clamps on the bottom of the air box can be a PITA sometimes to get back on - you tighten the screw.. almost snug... and it pops off.
I think over time and heat the airbox deforms and no longer wants to sit in place
try cleaning the top of the carb, the inside of the airbox, the clamp.. with alcohol and wipe it all down dry so its plastic to metal contact, with no oily gas acting like lube. The engine breather hose goes into the airbox, venting the oil fumes from the crankcase, so the inside of the airbox normally gets oily.
Reading your post again, did you see gas leaking out of the bike anywhere?
with a carb'ed engine its normal for it to smell like gas when the engine is hot. The gas in the float bowls literally boils out when the bike is parked hot, and you smell the fuel vapor coming off the engine.
That does not happen with fuel injected vehicles, so most people are not use to gas engine smelling like gas anymore.
one more thing - if this is the first time you rode this year, your gas has probably turned goopy unless you used a fuel stabilizer in the tank when you parked the bike for the winter.
if you did not stabilize the fuel when you parked it last fall, I would drain the tank, fill it with fresh gas, and use something like Seafoam to clean out any gunk in your carbs. As long as the bike will run Seafoam will do the job.
If you cant get the bike to start again it may have sucked some goop in from the tank. In that case you will need to get some seafoam into the float bowls, and let it soak overnight.
Yes I saw gas dripping from the carbs and as best as I could tell it looked like it was coming out of the airbox tube where it connects to the top of the carburetor throat. doesn't make sense because it means the carburetor would have had to been full and overflowing but that's what it appeared to be. It ran several miles with the gas leaking and it was only after stopping and then turning the bike off and restarting I went a couple blocks and that's when it basically was flooding out and would not run. The reason I just checked the front bowl is because that's where the gas appeared to be leaking I didn't see it coming out of the rear one. I did take the main jet off and look at it it looks clean. so I just put it back in and was going to reassemble and see if it would start again. That's when I had problems getting the breather box connected back to the carb throat. so I will try cleaning that stuff off I was thinking about that sounds like a good idea.
ok... now its making sense
there is no way the carb filled to the brim and leaked out the top, and you then started the bike - it would suck all that gas right into the front cylinder and hydro lock the piston into the head on the first compression stroke. I know you are new but around here we obey the laws of physics :^)
More likely is your gas tank is leaking somewhere over the front carb, its dripping down on the air box, running down the inside or outside, and coming off the connection point between the airbox and the front carb.
or maybe you have a fuel line failed or the connection to the fuel filter under there, and the fuel pump is spraying gas up on the air box under the gas tank...
BTW, talk to Scrumdown about riding a mc with a fuel leak - Bertha almost burned to the ground.
Ok, Thanks. I'll check all those ideas. Yeah, I hadn't planned on riding with gas pouring out lol, just started smelling gas, thought it was the car in front, then after a while realized it had to be me...oops :) Luckily it was dripping onto a little rubber coated metal "pan" that sits under the carbs and dripped onto the left side away from exhaust. ; Even so I was probably stupid to think I could drive it home after realizing the leak...luckily it flooded before exploding :)
KCW re: "if the float is stuck low in either carb float bowl there is an overflow tube that goes down just above the top of the crankcase on the right side of the bike."
The only tube I can see is a rubber 3/8ish tube that tees between the carbs and runs down to a bracket just above the engine, but it's on the exhaust side, I would think they'd want it on the opposite side, but is that the one you're talking about? It's definitely not crimped.
was wondering if I can clean the needle valve with carb cleaner as it has a rubber tip?. have melted rubber orings but that was with brake cleaner so maybe carb cleaner is different? There was the slightest yellowish tint on one side of the needle so maybe that was some build up that could have stuck even though it didn't seem to be the least bit tight when I took it apart. (always run ethanol free gas and yes, stabilized when parked)
There doesn't appear to be any leaks in the tank. There was no leaking when not running so maybe your thought of fuel filter conx though I can't see anything with the naked eye. maybe i'll put some clothes on it and try again lol.
will try to reassemble and see if i can repeat the issue if I can get that darn airbox back on ha!
carb cleaner will be fine on the float bowl and needle valves
brake cleaner is nasty stuff
you found the overflow hose - the one you described that goes to the right side - it the float was stuck it would be coming out of that hose
if nothing is dripping with the ignition off then your tank is not leaking, it has to be a fuel line cracked or pulling off somewhere. The fuel pump only runs when the key is on and the kill switch is set to run
Its possible the gravity of the fuel in the tank is not enough to make a failed gas hose leak but when you turn on the fuel pump it starts to spray out.
you can clean that air box connection point with carb cleaner too. What you really need is someone to hold it down while you torque the screws on the clamps.
edit: that air box connection is maddening - the first time I did my valves I had no problem. The second time it took me 30 minutes to screw those two clamps down - and its the last thing you have to do, then put the gas tank back on and you are done, but nope.nope.nope.nope....
Yeah, I was holding it down with one hand while tightening with the other and it just acted like the throat casting was tapered, the tighter I went the more it raised up. But have cleaned now and will try again. Glad I stumbled onto this great resource! Thanks KCW
You know what we have to get is a pocket KCW so he is always there when you need him.
Don't use Carb cleaner on any plastic or rubber parts, it will deteriorate them. Older orings that are not nitrile will also deteriorate. Use Carb cleaner only on metal parts, that's is experience taking, bad experience. 🙁
Discussion Starter #12
oh this is embarrassing
seems like he is! :wink:
update on my issue: problem found!!! I'm an idiot!!! Put it back together, noticed that with the tank installed I can't even see the upper boots conx to the carb...so how did I see it leaking there? Turn on gas, turn key and voila!...there it is pouring out of the lower boot conx on front carb...which looks just like the upper conx to my aging and dyslexic eyes! duh double duh. by the time I had taken apart after the day the problem occurred it was a couple weeks later and when I saw the upper conx it looked like what I remembered from that day...how dumb can I get...don't answer that....
So with a less inaccurate description of the problem is there a different area I should be looking at? I don't see any leaks above or shooting from the fuel filter or hoses it's just running out of the rubber boot that attaches to the bottom of the carb and goes into the cyl once the fuel pump starts running
Great you got it fixed. Don't be embarrassed. The simplest things are easily missed. Like when someone asks why their bike won't turn over one of the first suggestions is the kill switch on or off. We have all had those moments. So now when someone says their bike is keaking gas you can chime in on what to check.
.there is gas pouring out of the lower boot conx on front carb...
good that you were able to zero in on the point of the fuel leak
bad that it appears to be coming out in the front intake boot to the carb
for one thing, that boot should be sealed at both ends, if you filled it with gas nothing should leak out
2nd, nothing in the carb should be leaking like that - the drain hose is designed if the float overflows it goes out the hose, so either the drain is plugged... the drain has to be plugged
unless the gas is flowing right out of a jet into the throat of the carb with no vacuum pulling it out of the jet?
are you absolutely sure the gas is leaking out of the intake boot? that would require a 2 point failure: the leak in the carb (jet spewing gas into the carb) and the boot leaking.
Have to wave the huge red flag now: if that much gas was leaking out of the boot, the inside of the boot must be flooded with fuel running right into the front cylinder. It does not take much gas to dilute the oil down from 20W40 to 1W2.
DO NOT start the engine up again until you are sure you have a crankcase full of pure oil.
If you can find the source of the leak, and its on the outside of the carb (like the choke jet fell out and its running gas down the outside onto the boot exterior) then your oil should be ok.
I recommend: look carefully again to see if the gas is leaking thru a leak in the boot
if your are not sure drain your oil out, see if it smells and looks like its diluted with gasoline
Les must have been posting before he had his coffee this morning, he thought you had the problem fixed.
Discussion Starter #15
I will try to find the location of the choke jet and see if it's leaking there. I'm thinking of how to hook an extension tube from the gas tank to the inlet with the gas tank out of the way so I can see what's going on
Discussion Starter #16
With tank back off I now see I forgot to hook the rear hose up to the airbox the little half inch rubber hose I'm sure that wouldn't have caused the leak but it speaks to my skills at mechanicing
Discussion Starter #17
Also I can confirm I see no evidence of gas leaking from the carburetor overflow tube exit point
Actually I was at work, same as being asleep. 😃
Discussion Starter #19
Latest update
tank off carburetor out I can blow through the overflow tube and gas shoots out of the vents inside the carb so that's not blocked
looks like a possible wetness on the bottom of the float bowl of the front carb.
Could it be as simple as a bad gasket on the bowl cover leaking onto the rubber connection to the inlet intervale cylinder and running down the outside.
no gas observed in the intake boot upon removal of the carburetor.I mean the boot is not full of gas to the top where it would be overflowing.
Don't know how long it would take to drain out if there were no valves opened and I don't know if the valves are open or closed.
but a new gasket is a simple thing to try and if that eliminates it woohoo!!
i think you got it, a bad float bowl gasket is the simplest cause of what you saw, and it would leak on the bottom and get on the intake boot like you said
no need to drain your oil then
[cancel red alert]
1 - 20 of 43 Posts
