Gas tank cleaning
845 Views 5 Replies 4 Participants Last post by  bpounds
New member here! A stripped bolt is preventing me from removing my gas tank for cleaning. Has anyone tried cleaning - like with apple cider vinegar - without removing the tank?
Not without removing the tank. But ... I have used Apple Cider Vinegar to clean the inside of a tank. It does a pretty decent job.
To remove a stripped, I have used these from O'Reilly's with great success. I purchased both sets, which covers 8-18mm or 10-16mm. Don't remember which. Can be used on standard sizes as well.
Ride smart! Ride often!
See less See more
Reactions: 2
Thanks for the reply. It looks like I may have to drill out the striped bolt (which is pretty small) and then find some other way of reattaching the speedometer housing. So much for being lazy!
Reactions: 1
Can you take a picture of the stripped bolt?
I ask because They make drill bits that will work of smaller bolt heads that are stripped.
4
Used Apple cider vinegar many times, but off bike. Here's my last one. It was a mess.
Before:
96487
After:
96488
What the stuff that came out of fuel filter looked like:
96489
Carb bowl:
96490
See less See more
Reactions: 1
I think it will be worth getting that tank off. And you want to fix the screw anyway, right?
Maybe show us a pic the offending screw. I...uh, some guy...uh, I heard of a guy who had stripped a bolt one time. We might have some idea to help you get it out. A speedo bezel screw would be a piece of cake compared to some places.
Reactions: 3
