So if I'm coming up to a light and down shift to 1st - zero problems
However if I shift to neutral at the light, then try and shift to first at times it looks to be in gear but when I take off it's clearly not - it will jerk and die like trying to take off in second
I can tell it's not going into first all the way
can I adjust my clutch to fix it or is it the actual clutch ?
Neither! (Assuming you don't have any other shifting problems).
You should always shift into 1st while the bike is moving & coming to a stop.
I always want to be in gear in case I have to move fast. That being said, if I downshift to1st while moving, stop, I'm able to shift into neutral, let the clutch out, pull the clutch in, and drop it into 1st no problem.
If you shift into neutral while your still moving, The syncros in the tranny aren't aligned properly.
I've had problems due to paying attention to miniskirts & halter tops, and come to a stop in 2nd. :wink:
What I do then is feather the clutch so the syncros get realigned, pull the clutch back in,
shift down to neutral, and repeat.
If you do have to adjust the cable, be sure the bike is at operating temp.
I've had problems due to paying attention to miniskirts & halter tops, and come to a stop in 2nd. /forums/images/StarbikeForums_2015/smilies/tango_face_wink.png
Got it, Thanks
I only really think about neutral after long rides or just want to sit back at long lights or something - normally am in first
Got it, Thanks
Yeah, I hear you. I come across some long lights & I also shift to neutral, but as I said, as
long as I was moving & shifted into 1st before I stop, I'm able to hit N and drop it back into 1st with no problem.
If I need to take my hand off the clutch at a stop I hit the kill switch. Then I can let go of the brake lever too, and the bike wont try to roll away under me because its still in 1st gear.
Ive done it both ways, it can take more time to try to get the bike into neutral, then kick it back into first to go again, than to blindly hit the kill switch, then turn it back on and nail the starter.
And BTW, if you ever have to put the kick stand down and jump off your bike at a stop, hit the kill switch but leave the key on - that keeps your lights on. Ive done this a few times to move rocks or debris off the road at a red light. You do not want your bike sitting on the kickstand in neutral with the engine running. Having the engine off and the bike in 1st gear IS your parking brake.
If you are having trouble shifting while the bike is stopped you can also duck walk the bike forwards or back a bit to get the gears to move in the transmission.
Slipping the clutch spins the gears from the input side of the transmission
moving the bike forwards or back moves the gears in the transmission from the output drive shaft side
either one will get the gears you are trying to engage off the tooth to tooth deadlocked position.
Good advice about the kill switch, that never occurred to me.
KCW
yes Sir, I've done the rocking method and now I just test it before light changes but normally just leave it in first
