The words that are missing on the description are "glass mat" - there is an acyronim for this, I forget what it is...
For a motorcycle you want an OEM replacement - the glass mat is just what it sounds like, fiberglass matting (padding) between the plates in the battery that make it more rugged, and keep pieces of one plate vibrating loose and shorting to the next one.
I got my last battery from... I want to say Battery Shark website.. It was only around $30 4 years ago with free shipping. The have regional warehouses across the country, it only took a few days for it to arrive.
Lead acid glass mat motorcycle batteries are a very mature product - which means there are a lot of people making them, making them very well, recycling the lead nearly 100%. The one I got for my 650 was made in Vietnam and I have no issues with it. Im due for another one next spring (4 years) and that is my plan.
Physically fitting in the spot and working and working properly are all different items. Cold Cranking Amps, Cranking Amps, Reserve, terminal type and position are all things to consider.
Can always go with a higher CCA and CA (to a reasonable extent) without worry. Too low and you won't be able to spin the starter over quick enough to get started up.
Positive and Negative swapped or wrong terminal type will cause you the headache of not being able to connect the wires to even try to start.
Reserve isn't called out much on small battery, but entails the amount of stored charge to run lights for a set amount of time without an alternator/generator recharging.
If you are worried on cost, you can get the old lead batteries that you have to add the electrolytic juice (battery acid) and charge prior to use.
A lot of headache can occur over a few dollars, a little research (like you are doing) can save a lot of trouble.
The terminals are on the correct sides and the screws appear to be the same. Not sure on the CCA. I'll be the Guinea Pig and pick one up and see how it works out. The bike is off the road and just want to get it up and running before the end of the season
Another place to get a good price on a standard glass mat battery is Interstate Batteries
if there is a Harbor Freight near you, there is probably an Interstate Battery store not far away.
AMG battery for $32., just a suggestion.
