Thought this might be interesting. Note I flipped the rear exhaust manifold to get a true dual. Let me know what you think. I have added a lot of Harley parts that I found in a swap meet.
Great job ! I'm hoping to do the same by next year.
Looking good!
I notice the front saddlebag supports attached to the rear peg mounts... What do they attach to in the back?
Pics ?
On the rear Saddle bags. I ordered them off EBay $249.00 painted black and came with all the latches, and fully assembled. I'm modifying the rear pegs switching right to left and left to right to get ahead of the bags. I will also weld spacers on them to get out past the tube I used to make the lower mounts for the bags. The tubing is 3/4" .125 wall from local steel company. I have a bender to bend it. The bags actually have a troff under the bottom that also has rubber insulators in them I set the bottom up first so the bags would be at the same hight. My bike came with leather bags so I used to original upper mounts I welded tabs on them to bolt to on the Harley bags, there tight as a drum.
