I replaced my headlamp bulb, and while adjusting the vertical and horizontal I heard a pop. I removed the headlamp retaining screws to discover the spring that holds the lamp in place had dislodged. I can't seem to get it back in the correct position. Perhaps the spring broke; although it seems to be symmetrical. Does anyone have an illustration on how the spring is loaded? Thank you, Tom
Thank you Sick Mick I was able to go to the link you provided, print out the picture of the spring and verify the correct position of the spring on my motorcycle. All of this under 45 minutes. Thanks for the help.
