07 Stratoliner, I want to adjust my heel shifter down some but after loosening the top allen screw I cant get the lever loose. Is there a pin behind it somewhere I'm missing ? The lever will only come out so far.. Thanks
There's a keyway on the shaft that the bolt goes through so you must pull the allen bolt all the way out to adjust.
You will need to loosen the two floorboard bolts, as well, in order to get the heel shift part out, in order to adjust it.
My 2007 Roadliner has the heel shift too high also. Tried to adjust it by one notch, but it came out too low (would hit floorboard before it could shift). I tried adjusting both sides with no good results. Just got used to the high heel shift.
Hope it works for you.
Frank
