Hello everyone, I just bought a 2003 1100 vstar . The clutch started slipping 2weeks after I got it. Long story short it's not the clutch itself , the clutch handle after shifting will sometimes not fully return leaving a small gap. The free play is only a nickel or less. Is this the lower adjustment I need to make , or the one on the clutch lever itself?
Any help would appreciate any help.
Welcome Lilsmokee, from southwestern PA. The manual states that the free play on clutch lever should be between .2" and .39". And also that if the proper adjustment can't be made at the lever, then you'll need to adjust it at the clutch release mechanism at bottom. Hope this helps.
