- Reaction score
- 1,670
I have often seen it suggested that you replace your helmet every 5 years. I've seen it said that if you have a get off you should replace your helmet then. That one I can understand. There maybe damage to the helmet, from the crash, that can't be seen by the eye.
What causes a helmet to loose its integrity after 5 years. The only possible thing I've been able to come up with is damage from the Sun being caused by UV rays. I don't know that I'm correct, but its the only reason I can think of.
Its coming up on the 5 year mark for my current helmet and I don't see a thing wrong with it. Do I really need to replace it? (I also have sitting on the shelf, right next to the current helmet, the previous helmet which also seems to be in fine shape which I replaced at 5 years.)
