Help
221 views 3 replies 4 participants last post by  Jspree
#1 ·
Tried to change my horn on 2009 1300 vstar and now the headlight, turn signals and the horn won't work. Can someone tell me where and what fuse I need to be looking for?
#3 ·
  • Helpful
Reactions: Jo hart
#4 ·
Question, did you just unplug the old horn and plug in the new one. Or did you cut the wiring and add a new horn. Also did you add a large horn that has more amp draw? When adding large horns you need to add in a power relay , the OEM horns are very low amp horns on a shared circuit.
