Hey all
I have a 2005 XVS1100, I had a Baron Big air Kit fitted and some delkevic 450mm pipes, Since all this 3 different bike shops have had trouble tuning it and all seem to point to the pipes, plus they are extremely loud so dont recommend, lots of popping and back fires, plus there is a bad vibration now coming through the bike at about 100k and up to 120 and beyond, Any thoughts appreciated
Thanks in advance
Discussion Starter · #3 ·
V-Star 1100 Wiki Knowledge Base - 3 Tuning your have to jet it correctly.with the big air and the open pipes your probably lean so turning the pms screws out a quarter turn might be enough. upping the mains one size, try 115 in both cylinders. sincing the carbs will get rid of the vibration.
I believe they put the 115 in the front and 112 in the rear as per the Air kit instructions but your saying to put the same in both?? One of the shops did say that it was possible the carbs were out of sync perhaps but they could not see where.
