1 - 14 of 14 Posts
I was trying to figure out the best way to check oil. If you are supposed to have it upright and look at the window. I believe this is physically impossible for me without landing on my head. Do you put a 2x4 under kick stand?
I have a smaill 2" mirror on a telescopic stem. Works great. I keep in in the bag.
get a little piece of a mirror
put the bike in gear and hold the brake if the window is on the left side of the bike
sit on the seat, bike vertical, reach down with mirror - easy
this is a good time to point out, because the oil filter fills with oil when the engine is run, and depended on which bike you have it may slowly drain out after the bike has sat (over night, over a week...) its best to check your oil after you have rode a few miles, let it sit for minute to let the oil drain down from the heads, then check it
if you check it then, check it in the morning again - if its the same then just check it in the morning from then on
the potential problem is, if the filter slowly drains out and you check it, it will look hi, or full when its not.
BTW< if you want to stand your bike up to work on it, get a couple 4x4s or a 4 x 6 and a 2x4 block of wood andand make a solid stack of blocks that fits under the frame on the right side of the bike (just behind the engine, lean the bike up on it solid, then slide some wood under the kickstand to hold it level
I've got a lighted inspection mirror, works great. I've dropped stuff way to often while working on cars. I glued a magnet on end of lighted mirror to pick up my loose screws. ?
while we are talking about clever ways to do things, this year when it was time to get my car inspected no one was around to check my tail lights, turn signals... to see if any bulbs were out
so.. empty coffee cup, cell phone, 2 minute video of me stepping on the brakes, reverse lights, turn signals... easy.
(coffee cup makes excellent cell phone camera tripod)
Dang you guys are smart i never thought of a stick mirror.
I do have a cycle jack but heard you have to adjust to lift bike because motor is lower than frame. I haven't tried it yet. I do need to make it work for cleaning spokes.
(to clean coating from playing cards cloths pinned on)
I have mounted a small [1/2" x 1"] mirror on the floorboard. There are commercial ones made ,but it is real simple to make , just a mirror a small piece of aluminum and a small bolt .
It works great! Just sit on the bike and look down. Can even see the oil in the window when idling, it's a bit lower than when stopped and when you rev it a little it floods the window.
Checking oil level on v-star 1300
I usually place a small level on the gas cap, and have my girlfriend hold the motorcycle upright while she keeps her eyes on the level, I check the oil level.
Did you facetime it to your self too?
i made an aluminum bracket with a mirror on it, bolts to the floor board, you can but them on the interweb, but i like to make stuff.
Yes checking fresh oil is a pain hard to tell if it’s over filled after a couple of rides get the brown color and makes it easier to tell. But I’ve really never seen any of my bikes loose oil or burn it. But then again I probably change the oil more than I have too. I don’t change the filter every time as at 2000 miles it should be fine.
Going thru that right now. Just changed oil and filter. Previous owner of the bike put a chrome dipstick on it. It's chrome from tip to tip and smooth as a baby's bottom (no hatched area). Can't tell where the heck it is on the stick.
1 - 14 of 14 Posts
