So lost my key but thankfully its only $18 for a new one made if I bring the ignition to the Locksmith. (yes, im having 2 keys made)
FYI: wire cover over the Main Ignition Switch is only 1 bolt (12mm?)
then you will need a TORX T40 (Tamper Proof kind) $3 at the hardware store to remove the Main Ignition Switch itself.
Disconnect the wiring connector and your golden.
Having a bad run of Luck.. 2nd Flat in 2 weeks, Towing ($140) + lost key.
Sounds like you have the bad luck out of the way and can look forward to a great riding season. Thanks for the heads up on the ignition removal.
I only got one key with my '03 when I bought it and the locksmith was probably one of my first stops for parts. Guess I kind of raised my voice in surprise when I repeated his price of $10 to cut a key but couldn't argue with his logic about it costing a hell of a lot more if I lost my only key. I now have 3 keys. Keep one at home with all the other spare keys for emergencys, one I use and the other is hidden on the bike just in case I lose the main key while on the road.
