· Registered
Reaction score
0
I have an '07 custom 1100 and have bought a clock which fits over the 27mm nut between the handlbar risers.The nut needs to be turned about a quarter of a turn so the clock will fit level.Is there a problem doing this and which way should I turn it ?
· Registered
Reaction score
6
I don't know what type of clock you have, but I have a stem mount (the same type you are referring to) clock from clocks4bikes on my 1100. When I installed it, I removed the insert (the actual clock part) from the mount first, secured the mount on the nut, and then replaced the insert so it was properly aligned.
Don
· Registered
Reaction score
0
hmmmnnn reading....what a concept...been there, dontcha feel better now?
