1 - 11 of 11 Posts
Got my Cobra Speedster Longs exhaust installed today, man they sound good and look the business. Couldn't be happier.
Thing is, they're not perfectly aligned, the front heat shield is a little skewed (not snug up to the exhaust flange at all) and I can sense strain - once I took them out for a quick ride and the bike started cooling down the misalignment became more pronounced. The end of the pipes are supposed to be exactly aligned but they're about 4-5mm off.
The other thing - there was a small amount of white smoke coming out the tailpipe and also at the manifold on the rear pipe. I think it calmed down a bit - is this normal for new pipes? I replaced both exhaust gaskets with new ones.
There's also a fair amount of popping on deceleration but I'll be re-jetting the carbs asap.
Thinking about taking it all apart and trying again in the morning. I love this bike so it won't be a ballache - do you think I should or am I stressing over nothing?
Thanks one and all =)
I have a Cobra Slip-On on mine and reading that popping and backfiring (I call it) is normal to an extent. One thing I did which helped was to reset the ECU. I disconnected the battery and left it for about 30 min and reconnected it. It greatly helped but did not eliminate it all. I have also read that the Cobra Fuel Management module helps a lot more. I plan on adding an air intake on mine like the Cobra and will be looking at that module in the future. I am sure others who know more and have more experience will jump in here to help. Enjoy your ride and be safe out there!!
Bill
Reactions: Keith Post
Discussion Starter · #4 ·
Thanks guys, really - this forum is such a huge help for a guy like me who's learning the ropes. If I could I be buying the beers.
Ok, I'll try disconnecting the battery and see if that helps. I'll also look into turning the kms screw but to be honest I have literally no idea what that is or where to find it - I'll see if I can find some info online and I'm sure there's some out there.
Any idea about the smoke? It could just be the "new" burning off the pipe, I'll hold a tissue up to the rear exhaust manifold tomorrow and see if there's a leak there (there was smoke coming out there as well). I'll let you know how I get on.
I'll try and take a pic of the front heat shield too - it's way off (and yeah, my lower pipe is way lower than the upper one). Might this mean the alignment of the head pipes and muffler is not right? Could this be a "du-du-du-duuuuuuhhhhhhh" bad thing?
https://docs.google.com/file/d/0B-KrKk_YXL4Tdm5OU1I4S2pMUFE/edit follow the jetting instructions and it shows how to drill the factory plugs that cover the pms "idle mixture screws".white smoke possible rear valve cover leaking.clockwise turning in makes them leaner and counterclockwise screwing them out makes it richer. try a quarter turn."out"
Discussion Starter · #7 ·
Thanks for the link - so I don't need to re-jet the carbs but do need to remove the carbs to get to the pms screw? This looks pretty intense - I'm all for having a go myself but this would definitely be the most mechanical thing I've done! I'm up for it - does anyone have any advice or tips? I'm not kidding - I'd really be going off the deep end if I try this myself.
I use this link a lot. Its for the 1300, but some of the advise might give you a direction to look also for more infio and some ideas.
Bill
V Star 1300 Wiki / FrontPage
Discussion Starter · #10 ·
Update on the pipes - woke up this morning and after looking at yesterday's exhaust install I knew I has to take them off and try again. The alignment just wasn't right. So, armed with a couple of cold ones the heat shields came off, all the bolts loosened and I tried shuffling everything more snug. Got the heat shields back on and it's a definite improvement. Not perfect, but way better. Bottom pipe maybe sticking out 1 or 2mm now, that's it. I can live with that.
No smoke anymore, so think that must have been the "new" burning off. I'll keep an eye on it.
And I'm going to try adjusting the PMS screw this week. I'll order some after market replacement screws (from Metric Magic) to make adjustments easier in the future. Looking forward to the next project - damn I love my bike.
2007 VStar 1300
Oh yeah - which way do I turn the pms screw, clockwise or counter?
Ideally, you should make sure the screw is set to spec in the first place. Find out how many turns from having it seated, and set it there. Run the bike and see if the popping has been cut down, eliminated, or made worse. Adjust from there as needed.
1 - 11 of 11 Posts
